GT-40 Idle issue
  • jc
    • Jun 2004
    • 221
    • Morinville AB. CAN
    • 2008 Super Air Nautique 230 1997 Ski Nautique
    GT-40 Idle issue
    So just picked a 95 SNOB, first couple times out I noticed it seems to idle quite high on start up.
    When it fires up it revs up to around 2000 rpm for about 5-10 seconds then Idles back down to 1000.
    At first I thought it was perfect pass related but I’ve ruled that out. Also happens warm or cold and I need to wait 5-10 seconds to idle down before I put the boat in gear.
    Was a California boat now living in Alberta Canada.
    Thoughts? Throttle position sensor? I’ve owned a few GT-40 boats and never had this issue before.
    Thanks in advance!
  • jc
    • Jun 2004
    • 221
    Anyone?
    Any ideas?
    • windsurfnut
      • Mar 2018
      • 69
      • Ontario
      • 2002 Ski Nautique
      I'm new to the GT-40, but in my experience a bad/failing IAC (idle air control) valve show these symptoms.
      • Tom_H
        • Jan 2014
        • 244
        • Minnesota
        I would say either an IAC issue, or check your throttle cable and make sure it's not leaving the butterfly open a little bit in neutral, causing the IAC to take some time to meter it down from its start position because of excess air getting in.
        • jc
          • Jun 2004
          • 221
          Yes this would make sense. ill have a look this weekend.
          Thanks
