When I start the boat after sitting up for days, there is a squeaky noise coming from what appears to be the belt. The motor is the PCM Excalibur motor. I've read that I should spray some oil on belt, check tensioner or replace belt. Any recommendations on diagnosing the problem?
How old is the belt? They're not that expensive and not that difficult to replace. If it's old, or you don't know how old it is, then replace it.
-Charles
I have a 2004 SV211 and had the same noise awhile back. It turned out to be my water pump.
