Squeaky noise coming from SV211 2007 when I start it cold
  • ROCKer
    • Jun 2012
    • 55
    • Madison, MS
    When I start the boat after sitting up for days, there is a squeaky noise coming from what appears to be the belt. The motor is the PCM Excalibur motor. I've read that I should spray some oil on belt, check tensioner or replace belt. Any recommendations on diagnosing the problem?
  • charlesml3
    • Jan 2008
    • 2455
    • Lake Gaston, NC
    • 2022 G23
    How old is the belt? They're not that expensive and not that difficult to replace. If it's old, or you don't know how old it is, then replace it.
    -Charles
    • ROCKer
      • Jun 2012
      • 55
      • Madison, MS
      The Nautique dealer supposedly went through the boat and serviced it before I got it. With that being said, there's no telling how old the belt is. I'll replace it and keep the other as a backup in case I have an emergency.
      • coryk
        • Feb 2010
        • 34
        • Kentucky
        • 2015 Super Air Nautique 210 - Current 2004 SV211 1985 Ski Nautique 2001
        I have a 2004 SV211 and had the same noise awhile back. It turned out to be my water pump.
        • ROCKer
          • Jun 2012
          • 55
          • Madison, MS
          How did you determine it was the water pump?
