Lost my screwdriver in my 2007 SV211 engine compartment
  • ROCKer
    • Jun 2012
    • 55
    • Madison, MS
    While removing a ballast pump, I accidently dropped my screwdriver on the starboard side of the motor. I’ve tried fishing around with my magnet and only found a washer and a nut. Any ideas on getting it out or if it will hurt anything floating around down there. This simple fix has turned into a pain in the ***. To top it off now my boat lift is slipping and want raise my boat.
  • j2nh
    • Dec 2003
    • 628
    • Spread Eagle Wisconsin
    You should be fine. After the first ride check again. I've done it myself and those things turn up.
    What kind of lift?
    2018 200 Team H6
    2009 196 Team ZR 409
    2005 196 Limited ZR 375
    2003 196 Limited Excalibur
    1999 196 Masters Edition
    1987 ProStar 190
    • ROCKer
      • Jun 2012
      • 55
      • Madison, MS
      Got the lift fixed with some grease and now I’ve got to get the ballast pump working.
      • Dgee
        • Jul 2016
        • 137
        • Portland, OR
        • 1999 SAN
        Shouldn’t cause any issues, I found a whole socket set in the bottom of my boat when I bought it lol.
        • Shawn Henderson
          • Jul 2017
          • 121
          • Houston
          • 2006 SV211
          You can always pull the divider between the motor and ballast tanks they just pop out then you have pretty good access to the motor. Whats going on with your ballast pump is it not emptying the tanks?
          • ROCKer
            • Jun 2012
            • 55
            • Madison, MS
            My middle ballast pump is not working. It is getting 12.5 volts but will not turn on. I connected it to the starboard ballast connector and it ran fine. Where are the relays in this boat?
            • JayG80
              • Dec 2006
              • 206
              • Santa Fe, TX
              • 2007 Ski Nautique Sold 2002 Ski Nautique
              At least your not a surgeon. Screw driver in a boat will present itself at some point.
              • Shawn Henderson
                • Jul 2017
                • 121
                • Houston
                • 2006 SV211
                So when you push the button to fill or drain your getting 12.5v at the motor but the motor isn't running? Relays are under the steering wheel at the drivers feet
                • ROCKer
                  • Jun 2012
                  • 55
                  • Madison, MS
                  That’s correct on the voltage when I push the buttons. I’m trying to find the relays that actually sketch the polarity and allow the current to flow to the pumps. Someone told me they were in one of the rear storages. I’m going to track the wires coming to the pumps.
                  • charlesml3
                    • Jan 2008
                    • 2456
                    • Lake Gaston, NC
                    • 2022 G23
                    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
