Running a Little Rich... anyone run injector cleaner? Gt40
  • brettmcox
    • Jan 2007
    • 284
    I have a GT40, I have notice a little gas smell from exhaust.
    Not having any POWER issues.
    New plugs wires and rotor a few years ago.
    Could use a New FCC filter...
    Thinking about running "Sea Foam" or something like that...
    any recommendations?
    2001 Super Sport - GT40 1986 SN2001 - 351 1973 Cobalt - 188/888 2014 F150 Screw 3.5 twin turbo 2011 Expy 2002 F150 SCrew 2001 F150 SCrew 1973 K5 (toy) 1995 Burb 3/4 454 1991 K5 Blazer (DD/Toy) 1987 Honda Accord 1978 Ford F100 1981 Merc Capri 1991 Honda Civic 2002 Ninja 500R sold...
  • SatherG230
    • May 2018
    • 83
    • MN
    • 2012 SANTE 230 w/ NSS
    I always use non-oxygenated premium fuel and add some Sea Foam at every fill-up. Engine runs great and I want it to continue running well. As part of my winterization, I try to have the tank near empty and add a can of Sea Foam to whatever fuel is left in the tank. I then idle it for a while before spraying some good fogging oil into the air intake as the last of my anti-freeze is sucked into the system. In the spring, I top off with fresh fuel and go. I have had Sea Foam help some of my small engines run better - I cannot see where it would hurt.
    • DVskier
      • Sep 2014
      • 82
      • Seneca SC
      • 2004 Ski Nautique 196 LE
      I agree, add the Sea Foam and fill the tank with non ethanol mid grade fuel. You'll be happy.
      • Infinity
        • Sep 2017
        • 730
        • Lake Norman - Denver, NC
        • 2014 SV244 w/ ZR409
        With larger tank, you may need quite a few bottles of it added to tank to mix the ratio that they spec
        • brettmcox
          • Jan 2007
          • 284
          I run 91 E-0 gas MOST of the time. I also put Stable Marine in the gas.
          I will add NON ethanol sea Foam... or Gum Out?
          Question... is it OK for these to Stay in the Tank for a few weeks. I ask because we tend to only Run 1 to 3 hours a week... when not on vacations.
