Heater removal?
  • Baken
    • 45
    • WA
    Heater removal?
    I removed my heater for two reasons:
    1. Never used it
    2. Needed space for 2nd battery
    My question is, should I plug the two ports from which the hoses came from or is running a short hose from one port hole to the other okay?
    I'm asking this cause I currently have a short hose running from one port to the other and my temp gauge jumps from 160 to 210 and it never did that before (new impeller installed this yr).
    1993 SN
  • Sbt3
    • Dec 2004
    • 164
    • Okauchee Wisconsin
    RE: Heater removal?
    I don't think it would be a problem running a short hose between the two, but I would probably just put the plugs back in. One less thing to worry about getting the water out of when winterizing or having it leak during the summer.
