PCM EX-343 Hesitation
  • Lwalker
    • Jun 2017
    • 6
    • Panama City, FL
    • 2008 SV211
    2008 PCM EX-343
    189 hours
    Symptoms:
    Rough/Low Idle(seems low, gauge says about 525, book says it is supposed to be 650)
    Skipping/Hesitation at cruise
    Bogs down at take off...have to ease into the throttle
    Purchased boat in June 2017 with 170 hours on it
    Actions so far in order:
    Drained fuel after purchase and filled with 89 octane non-ethanol.
    Replaced FCC Filter
    Replaced inline fuel filter
    Put 20 hours on it last summer
    Replaced Distributor cap
    Change oil and oil filter
    Went to the lake yesterday
    The symptoms have not changed. The boat is usable with the symptoms but I am ready to get it running smooth.
    Info:
    Idle - 525 RPMs - 158 Degrees - 38 PSI
    Idle, In gear - 500 RPMs - 158 Degrees - 45 PSI
    2900 RPMs - 25MPH - 143 Degrees - 62PSI
    4400 RPMs - 37MPH - 143 Degrees - 71PSI
    Voltage is 14.3 on the gauge
    What should my next step be? Thanks in advance for any help.
  • Lwalker
    • Jun 2017
    • 6
    • Panama City, FL
    • 2008 SV211
    Based on some more research, I think I am going to change the plugs first....seems that some others have experienced this with bad/worn plugs.
    • ScooterMcgavin
      • 1478
      • 2014 SAN 210 TE
      your on the right track with the plugs,if that doesn't fix it, move on to the rotor and plug wires.
      1989 Sport Nautique
      • surroundsound64
        • Jul 2005
        • 2147
        • Longview, TX
        • 2018 230 1981 Ski Nautique
        I had the same issue with my 343. Bad plugs.
        2018 SAN 230
        1981 Ski Nautique
        Sold - 2011 Sport 200V
        Sold - 2000 SAN
        • Infinity
          • Sep 2017
          • 730
          • Lake Norman - Denver, NC
          • 2014 SV244 w/ ZR409
          x3
          • SuperAirIan
            • Jan 2009
            • 35
            • Alberta, Canada
            • 2001 SAN 8.2L Python, FAE, 2.3K, 4 Johnsons
            Same problem last year. New rotor, cap, plugs and wires. Don't honestly know what cured it explicitly, but something in that combo sure did the trick. I hadn't done any of that in 7 years so it was high time.
            • Bevostein
              • Jun 2008
              • 521
              • Frisco, TX
              Plugs
              • Lwalker
                • Jun 2017
                • 6
                • Panama City, FL
                • 2008 SV211
                Thanks Guys. It was the plugs. Whole new boat.
                • ScooterMcgavin
                  • 1478
                  • 2014 SAN 210 TE
                  Awesome! Glad it worked out and thank you for reporting back that it fixed your issue.
                  1989 Sport Nautique
