2010 SN 200 overheating at idle
  • chipkimball
    • Jun 2018
    • 2
    • Washington
    • 2010 Natique 200
    Hey SN tech gurus - wold love some help. I have a 2010 SN 200 with the EX 343 engine. We have run into an overheating problem when the boat is idling, even for a short period of time. When the boat is up to speed - say fater than 20MPH, it cools right down and runs normally. Changes the impeller just in case, it was fine. Seems that if we had a clog, we would have overheating at any speed. Any ideas on trouble shooting this?
  • Lwalker
    • Jun 2017
    • 6
    • Panama City, FL
    • 2008 SV211
    What are the temps at idle and at speed? I would look at the thermostat next.
    • j2nh
      • Dec 2003
      • 628
      • Spread Eagle Wisconsin
      I would be looking for an air leak. Spinning the impeller faster might overcome the leak. Check hose clamps on the suction side, check the gasket on the strainer.
      2018 200 Team H6
      2009 196 Team ZR 409
      2005 196 Limited ZR 375
      2003 196 Limited Excalibur
      1999 196 Masters Edition
      1987 ProStar 190
      • chipkimball
        • Jun 2018
        • 2
        • Washington
        • 2010 Natique 200
        Thanks for the suggestions. Turns out the strainer platic had a hard to see crack (along the thread line) and when I replaced that part, everything now works fine. Everyone's help is much appreciated!!! Problem solved.
