What octane should be running 2002 Ski Nautique Ford 351
  • Houndawg100
    • Apr 2018
    • 1
    • Michigan
    • 2002 Ski Nautique
    I’m sorry if this a repeat question in this forum. I can’t find a solid answer. I simple yes or no will be fine. 1. Should I run the 87 octane with 10 percent ethanol?
    2. Or, should I run the 91 octane with no ethanol?
    Signed,
    Feeling dumb.
  • JayG80
    • Dec 2006
    • 262
    • Santa Fe, TX
    • 2007 Ski Nautique 2002 Ski Nautique 1999 Moomba Outback
    "Use any good grade of automotive regular or premium gasoline with a minimum average octane rating of 89. An 87 average octane gasoline can be used if 89 octane is not available" quote from Manual page 8.10 that happened to be on my desk ;-)
    • SatherG230
      • May 2018
      • 92
      • MN
      • 2012 SANTE 230 w/ NSS
      If you want to avoid problems, use premium non-oxygenated fuel. 91 octane W/o ethanol. Fuel tends to sit in boats for a while. Ethanol absorbs moisture.
      Premium stays fresher longer. That especially goes for small engines
      • CHassmann
        • Jul 2004
        • 527
        • Holiday Lakes, OH
        I can't get fuel in my area that does not contain alcohol for my '02. If I were in your shoes, I would definitely choose the 91 octane without ethanol. I normally use 89 with sta-bil 360 Marine ethanol fuel treatment. I occasionally run higher octane or use fuel injector cleaner.
        Ski on dude!
        • SatherG230
          • May 2018
          • 92
          • MN
          The Stabil Marine is good stuff. Stay away from the regular Stabol (red label). My local small engine guy says that is what keeps him in business! Seafoam is also a good additive. If you have to run ethanol, Star-tron enzyme treatment is also good to use.
          • Nautiquehunter
            • Jun 2008
            • 2099
            I must be the luckiest guy in the world. I have 5 boats all run on the cheapest 10% ethanol gas I can find. My 08 has over 1000 hours no problems yet?
            • charlesml3
              • Jan 2008
              • 2487
              • Lake Gaston, NC
              • 2022 G23
              Ha! ha! Actually, you probably understand the realities around Octane and Ethanol...
              It's amazing how in 2018 there is still so much myth around this.
              -Charles
              • Wake.BC
                • Jan 2016
                • 423
                • BC, Canada
                Coming from an indmar guy I think these high octanes are crazy. Just do what your manual tells you and everything should be fine. Even my dealer was like yeah... just run 89
                • charlesml3
                  • Jan 2008
                  • 2487
                  • Lake Gaston, NC
                  • 2022 G23
                  There are a lot of myths around high-octane fuel such as:
                  - It'll last longer in a gas can or in your gas tank.
                  - It cleans your injectors
                  - It'll let the engine create more horsepower/torque (only true if the engine can tune itself for higher octane fuel).
                  - It'll make your engine last longer.
                  - 93 Octane fuel is better than 89 which is better than 87.
                  • Wake.BC
                    • Jan 2016
                    • 423
                    • BC, Canada
                    If I had the 575 I would definitely run 91 which it calls for but with the 440 89 is fine so that’s what I run....
                    • charlesml3
                      • Jan 2008
                      • 2487
                      • Lake Gaston, NC
                      • 2022 G23
                      Yea. Higher compression engines (especially those with forced-induction) are what high-octane fuel is all about. The octane helps eliminate pre-ignition or "spark knock" as it's usually called. If you have to run a lower octane fuel in one of these engines, the ECU will detune the engine to eliminate the pre-ignition (with a corresponding reduction in HP/torque). On the other hand, running a high-octane fuel in an engine that doesn't need it won't do the opposite. In other words, it cannot "tune up" to take advantage of the higher octane.
