Vinyl Cleaning-Mildew Spots
  • Pitty
    • Jun 2017
    • 32
    • Canada
    • 2002 Super Air
    Looking for the best way/cleaner to remove black mildew spots from the vinyl. These are from the previous owner and may have been there for years, as ive tried elbow grease with aurora marine vinyl cleaner, but not having muck luck. Any advice would be appreciated
    Sent from my SM-G930W8 using PLT Nautique mobile app
  • charlesml3
    • Jan 2008
    • 2479
    • Lake Gaston, NC
    • 2022 G23
    This is the problem with mildew when it's ignored. At this point, the mildew is gone, but the stain remains. Try a mixture of bleach & water. See if that'll diminish the stains. You can also try a Magic Eraser, but be careful. They can get really abrasive.
    -Charles
    • Pitty
      • Jun 2017
      • 32
      • Canada
      • 2002 Super Air
      Thank you Charles, i will give it a try. I have also been reading about Malco leather and vinyl cleaner, have you had any experience with this product?
      • Wake.BC
        • Jan 2016
        • 423
        • BC, Canada
        Are you really getting it wet and scrubbing with a brush? That can make a big difference
        • charlesml3
          • Jan 2008
          • 2479
          • Lake Gaston, NC
          • 2022 G23
          Sorry, no. I haven't heard of Malco. For vinyl, I always use Fantastic, 409 or bleach & water. Once it's clean, I use 303 Aerospace to protect it.
          -Charles
          • Dgee
            • Jul 2016
            • 137
            • Portland, OR
            • 1999 SAN
            Malco with a magic eraser should get it all out. The combination is amazing, Malco puts all the other cleaners to shame.
            • goldfisch
              • Apr 2015
              • 29
              • elkhart indiana
              • 2001 sante
              Star bright mildew and stain remover from Walmart worked great for me. good luck
              • Pitty
                • Jun 2017
                • 32
                • Canada
                • 2002 Super Air
                Thanks everyone for your advice, im sure one of these will work.
                • scottb7
                  • Aug 2011
                  • 2198
                  • Carson City, Nevada
                  Yep, use the star bright mildew stain remover. It works. For tough spots you have to spray, then wait a while, then lightly brush with soft bristle brush, then repeat, spray wait, light brush. It does work!
                  I got my boat out of florida, and it had tons of mildew stain. It all came off...
                  Better yet buy the malco and the star bright and do a compare for all of us!
                  • ScooterMcgavin
                    • 1550
                    • 2014 SAN 210 TE
                    I'll second this method, and it would be great to see a side by side on each product.
                    1989 Sport Nautique
                    • shag
                      • 2217
                      If you use bleach any wear near the stitching, flood the area with fresh water when finished...
                      • Infinity
                        • Sep 2017
                        • 730
                        • Lake Norman - Denver, NC
                        • 2014 SV244 w/ ZR409
                        Dollar Store also sells something called "LA Awesome" cleaner...very similar to Malco, but for $1. You can dilute and use soft bristle brush. It works amazing on tough stains, but you gotta be careful with it, clean up really well after using and then condition the vinyl with the 303 (several times if you are me).
                        • ag4ever
                          • 1180
                          The best bleach based product I have found is Shoreline Marine - Mildew Stain Remover. I also use magic eraser to hit the stubborn areas.
                          Both of these products are a last resort effort. They will strip the top layer off the vinyl and future reinfestations of mold/mildew will happen much easier. I decided to use them with the knowledge I was only prolonging the useful life of the vinyl by a few years, and plan to resin all surfaces in a few more years.
                          This was done after I left the boat in a storage unit with a cover for 2 years. All the vinyl had extream mildew stains. To the point I was about to replace all vinyl. I was able to get 99% of all stains out, and 2 years latter they are still gone. But the boat is now kept in a dry garage 99% of the time. Really does not get an opportunity for mildew to bloom.
                          whatever product you use, the higher bleach content, the better it works, and more damaging it is to everything.
                          • kmarine
                            • Jun 2017
                            • 109
                            • chicago
                            • boss gt40
                            10% bleech and water soak a microfiber towel ring out cover stain for 3 minutes keep wet. until stain fades repeat if necessary wipe do not scrub. wear old cloths do not get on any other fabric surfaces. rinse with wet towels to remove residue. this method takes time. I have repeated as many as 10 times before heavy black stains are gone. I have removed black stains from customer boats when they asked me to re upholster. I like to follow up a few days later with 303 protectant to keep material soft. you may want to use rubber gloves.
