Aquatic invasive species filter system.
  • lztat573
    • Aug 2006
    • 89
    • Idaho
    • 07 SV211
    Anyone have lakes or reservoirs that they have had problems getting on, because of the mussels problem. If so does your boat or have you installed the Aquatic invasive species filters, and has it help in the return of getting on the lake or reservoir? Also what have you been able to do to get back on the water in that area? We have three reservoirs within a few miles of me that I cannot assess because the irrigation companies have cut off boats with ballast tanks because they can't be inspected. I'm hoping that I can give them the information on wake-worx.com, and install the filter system, then once again to be able to access the reservoirs. Any help would be greatly appreciated.
    Sent from my SM-T550 using PLT Nautique mobile app
  • GMLIII
    • May 2013
    • 2792
    Different problem then you but I have this option on my Coastal Edition and while running it in fresh water the build up of algae around the filters was so large it caused the ballast system to fill at a much slower rate therefore my dealer took the filters out and it fills much faster. Just something to keep in mind if you install them
