I had my 01 Sport/Air Nautique W/ Apex Motor out over the weekend and encountered (2) new issues. Issue #1: After sitting for awhile, I hit start and didn't get anything. I wiggled the throttle forward/reverse a couple times then back to neutral, hit start and it fired right up. That happened another time or two like it wasn't seating in neutral, but as soon as I wiggle it a time or two and go back to neutral it fires right up. Issue #2: When I was starting for the first time Sunday I noticed the throttle was very stiff going from neutral to forward/reverse. I thought it was locked up but it went into gear and shortly after it was back to normal? Anybody ran into similar issues? Thinking it might be time for some maintenance or potential part replacement?
Shift cable probably needs to be replaced, and possibly the neutral safety switch as well.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Thanks Jeff! These look like cheap enough parts I will go ahead and replace. Without removing the existing cable first, is there a way to determine the correct length I need? I looked in my manual but didn't see anything. Online under the length description I didn't see my boat listed. I see 17ft, 18ft, 19ft, and 22ft cable.
