1999 SS power issue
  • raymanrox
    • Mar 2013
    • 65
    • raleigh nc
    • 1999 super air
    1999 SS power issue
    So, last two times out, we ran for several hours without a problem. While idling back to the ramp, I start speeding up, and boat briefly looses power. I pull back to neutral, its fine, and try it again. Same thing happens. We idle all the way back in. Shut off the motor at the dock. It will not restart, no power, except for the items that are hooked directly to the battery, like ballast pumps, etc. The next day, everything is fine again. Anyone else had this happen? Or have any idea what is going on? I did check for voltage going to the main breaker, got no voltage reading. Thanks for any help, ideas for what to look for, etc!
  • raymanrox
    • Mar 2013
    • 65
    • raleigh nc
    • 1999 super air
    I found it! Have a bad circuit breaker on the engine, its making intermittent contact. Oh well, only $70 if I fix it myself.
