2008 super air nautique 236. Hooked battery up backwards.
  • ryansims1
    • Oct 2015
    • 1
    • Mooresville North Carolina
    • 2008 Super Air Nautique 236
    Hooked up battery backwards. I had alternator rebuilt and bench tested ok. Batteries are just fine. For some reason the alternator is not charging the system. Any suggestions?
  • Beamteam
    • Jul 2022
    • 2
    • Sammamish washington
    • 2006 SAN SV 211
    For me it was the 100 amp in line fuse which goes from the starter to your main breaker. Easy to repair and you can bypass it in a pinch if you need to. $46 part on nautique parts.
