Conversation Starter
  • ButterRide
    • Apr 2016
    • 53
    • Lansing, MI
    • 1997 Super Sport
    Need some suggestions of best place to get a reliable starter. Last year I replaced my starter due to Bendix issues starter would not stay engaged. The first replacement lasted only 3 starts before the Bendix gave up, at that point the starter would only make whirring noise when you turn the key. So I returned it and the replacement worked through the rest of last season. Guess what the starter Bendix seems to be toast again, so I'm guessing the quality of these aftermarket starters is to blame. Any suggestions where to get a good quality starter? Or maybe I should find a shop to rebuild the original.
  • charlesml3
    • Jan 2008
    • 2453
    • Lake Gaston, NC
    • 2022 G23
    https://www.nautiqueparts.com/produc...manent-magnet/
    • ButterRide
      • Apr 2016
      • 53
      • Lansing, MI
      • 1997 Super Sport
      That's actually the starter I have.
      • charlesml3
        • Jan 2008
        • 2453
        • Lake Gaston, NC
        • 2022 G23
        That's the OEM starter for that engine. If you're continuing to break the bendix, then your problem lies elsewhere.
        • scootdogydog
          • Nov 2013
          • 2
          • MA
          • 1999 Ski nautique, Python 502 1986 2001 Ski Nautique, 351
          use a VOM to check for voltage at the starter when you are trying to start it. You could have a voltage drop due to bad/corroded connections.
          • ButterRide
            • Apr 2016
            • 53
            • Lansing, MI
            • 1997 Super Sport
            Thanks for the feedback... I'll run through the wiring to check and clean everything.
            • gary s
              • Mar 2015
              • 334
              • Algonquin IL
              Who knows where that starter is from,no where in the above link does it say it's an oem starter. If the picture is even correct,it does not even have a PCM part number on it,which is RA122014 assuming it's a Ford. If it is and you decide to go new google Arco 70125, they are made here and can be found for around 130.
              • charlesml3
                • Jan 2008
                • 2453
                • Lake Gaston, NC
                • 2022 G23
                That link is from Nautiqueparts.com. Do you really think they're selling knock-off replacement parts on that site?
                • gary s
                  • Mar 2015
                  • 334
                  • Algonquin IL
                  I did not say that Charles,those are your words. What I said was that starter is not an oem PCM starter. Maybe thats all Townsend can get since Ford is not supporting Windsor marine engines. There are other options for starters,the one I suggested is built in the USA.
                  Here is an example of a PCM oem part from their site- clearly marked in the text as a PCM part and with PCM part number
                  Click image for larger version  Name:	PCM solenoid.jpg Views:	1 Size:	31.8 KB ID:	559717
                  Here now is the starter not marked as a PCM part and not a PCM part number nor is manufacturer noted
                  Click image for larger version  Name:	non PCM starter.jpg Views:	1 Size:	29.3 KB ID:	559718
                  Here is another example of a PCM part still available to them from Ford since its also used in a million automotive applications -
                  notice the PCM part number
                  Click image for larger version  Name:	PCM part.jpg Views:	1 Size:	29.1 KB ID:	559719
                  Finally here is a oem Nautique part from Sherwood as you can see it is marked in their parts system as SHE Click image for larger version  Name:	non PCM part.jpg Views:	1 Size:	31.5 KB ID:	559720
