17 210 rpm
  • Free48
    • Jun 2014
    • 119
    • Montana
    • 2019 SANTE 230 2017 SANTE 210 2011 SANTE 210 1991 454 BFN 1989 SN 2001 Ski Ray inboa
    17 210 rpm
    Hey 210 owners, what are you seeing for rpms at WOT(wide open throttle)? I’m showing 5600rpm at around 4200’ elevation. This is a 17 210 with the 409 engine. Wondering if I have the correct prop.
  • Beach-TJ
    • Oct 2010
    • 207
    • Lake Lanier, Ga
    • 2004 SAN 210 TE
    There should be a sticker on the motor telling correct wot range.
    According to the manual 5,400 to 5,600 is the range, so sounds like you are there.
    Manual is here
    http://www.planetnautique.com/Correc...PCM17NONDI.pdf
    • charlesml3
      • Jan 2008
      • 2480
      • Lake Gaston, NC
      • 2022 G23
      Yea, looks about right to me. Why do you need WOT on that 210 anyway?
      -Charles
      • Infinity
        • Sep 2017
        • 730
        • Lake Norman - Denver, NC
        • 2014 SV244 w/ ZR409
        I have a ZR409....5600 is exactly correct WOT for that engine. (On my 24ft boat, I get 40mph at WOT but with the 14x14.25 prop I have #1847 & #1433, I still get tons of low end torque no matter how much ballast/people I have onboard, but I am only at 800ft elevation). Hope you were just going WOT for testing, you don't want to run over 4000rpm for "extended periods". Whether you have the correct prop depends on what you are wanting to do with the boat. You surfing....wakeboarding...skiing.....barefoot guy?
