I removed both rear hard tanks (the marina actually removed them) and plumbed in bags.
Starboard side - I was able to locate the factory cable/connection, so I removed the sensor from the factory hard tank and taped it on half full and connected it. the factory pump allows me to fill and drain and works well.
Port side - I cannot locate the electrical cable/connection (I have spent hours searching, it disappeared like it never existed) The factory pump fills perfectly but it will not drain. The light flashes on the port ballast button signalling it's draining but nothing happens.
Any ideas? How do I drain the sac using the factory pump?
