I have a 2017 GS20 and about two weeks i couldn’t steer in reverse. I know you aren’t able to steer because there is a rutter, but you can steer by putting it in drive and turning either to the right or left, and then you throw it in reverse and it will continue to turn in that direction. I was able to steer like this in reverse both ways up until two weeks ago. I can only turn the boat around to the left. I was definitely able to turn it around to the right but I can’t anymore. When i put it in drive and turn to the right, then put it in reverse it NOW only continues to go backwards to the left, when it should continue to turn in a circle around to the right. It makes parking and backing out very hard. I have no clue what would cause this or if im just insane. I haven’t looked at the prop or rutter because it’s in the water but I can. Could weeds stuck on it cause this? Or maybe a weird mechanical steering problem? Any help would be awesome.
Tags: None
The prop rotation direction of a Nautique V-drive boat will cause it to only back the rear to the right. This is due to prop torque, and the fact that the rudder is behind the prop, not in front of it. Doesn't matter if you have started a turn in forward or not, in reverse the prop torque should always pull the back of the boat to the right.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
With vdrive boats you either go shooting to the right or sorta straight if you turn the wheel all the way to the left. Also if you give it more gas and go a little faster you have a much better chance of going straight.
I’ve found on the smaller ski boats turning is reverse it actually sorta works.
