oil and filter change
  • 93Euro
    • Feb 2006
    • 94
    • California
    • 2006 air nautique 210 SE
    I'm getting ready to do my first oil change in my 06 210. Anyone know how to cross reference the PCM oil fitler to a FRAM, or does anyone know the part #.
  • Flux
    • 408
    • Palmdale, Ca.
    RE: oil and filter change
    Don't use FRAM, cheapest filter out there.
    Use the Motorcraft or Mobil1 filters, they are simply better.
    Start with the Motorcraft FL-1A, that's the one for my 02 Excalibur. I have a strong feeling they have not changed it, but I could be wrong. Walmart has them. Don't use Fram.
    • 93Euro
      • Feb 2006
      • 94
      • California
      I've always used FRAM on my cars & trucks. Never had any problems. I did buy Mobil last time though. It's just that FRAM is everywhere. I can try to cross reference the Mobil filter from the Motorcraft FL-1A
      Thanks Flux
      • 93Euro
        • Feb 2006
        • 94
        • California
        Another question. PCM manual calls for 15W-40 SM. I have some Mobil Delvac 15W-40 SL I picked up at WalMart for my truck. Will this be ok? What's the difference between SL and SM.
        • Flux
          • 408
          • Palmdale, Ca.
          Sure. I really cannot tell you about the differences in the oils. FRAM probably works fine, I just know they are cheaply made.
          • SNMike
            • 1001
            The Fram # is PH8, but I agree with Flux, use the Mobil 1 or Motorcraft. You can get them at almost any auto store, and I buy my Motorcraft at WalMart. :grin: Regards!!!! Mike
            2007 Ski Nautique 196 Limited/ PP/ Mods
            • Blue Ski
              • 164
              Here are a couple of links to some crude oil filter tests and an oil test. Basically the regular Fram is junk but dropping a couple of bucks for the Fram Tough Guard does pay off...
              http://minimopar.knizefamily.net/oilfilterstudy.html
              link: http://neptune.spacebears.com/cars/s.../oil-life.html
              • 93Euro
                • Feb 2006
                • 94
                • California
                thanks forall the info. I ended up getting the Mobil1 filter. I'll be using these in all my vehicles now. No more FRAM.
                • ag4ever
                  • 1180
                  The motorcraft is the same as a purolator, and they are good.
                  Personally I buy purolator as i don't want to give ford my money if I can help it.
                  Diesel oil is fine for gas engines, gas oil is not fine for diesel engines.
