G25 in salt water
  • mstober
    • Jun 2018
    • 2
    • North Carolina
    • 2016 Super Air Nautique g25
    G25 in salt water
    Hi all,
    Just moved from inland NC to the coast with my 2016 G25. I've only ever heard bad things about putting any type of wakeboarding boat in salt water but have seen a couple different models running around the inter-coastal. Was wondering if anyone could provide me with any insight on any modifications I need to do to my boat in order to put it in salt water or if this is just a bad idea in general?
    Thanks in advance.
  • Infinity
    • Sep 2017
    • 730
    • Lake Norman - Denver, NC
    • 2014 SV244 w/ ZR409
    They make a Coastal Edition, basically allows you to flush entire engine out after each use along with some other benefits, honestly not sure of them all but it helps for sure. Then you are also pulling the salt water into your ballast tanks, not sure how that is dealt with. Tough call cause while I would not want to put my boat in salt water, if I moved to the Coast and that was the only way to get out, I would make it happen. You need to do some research on what you should do to protect it (corrosion protection, etc) and decide if its worth using your current boat, or getting one that is a "coastal edition" so its a little more protected as that will probably help resale down the road as well for you cause I can guarantee you this, you WILL take a hit on resale, pretty much once used in salt no one inland will want it....but you will still have buyers there and if you protect it right and/or Coastal Edition, would think you can do ok. I know even if it cost me more, I would not give up surfing....I enjoy it way too much. Its simply a way of life for me at this stage in my life and NEED it for stress relief
    • Wake.BC
      • Jan 2016
      • 423
      • BC, Canada
      Just a warning your typical painted trailer is going to go to waste. I’d sell it well it’s good and buy a galvanized.
      • glassywaters
        • Jan 2015
        • 225
        • florida
        • none
        I'd sell and buy a coastal edition. Well worth the time and money. Salt will eat up your boat otherwise and depreciate much faster.
        • shag
          • 2217
          Salt destroys everything... Well except fiberglass.
          • Infinity
            • Sep 2017
            • 730
            GMLIII has a Coastal Edition boat, perhaps he can tell you all the differences so you know the pros/cons
            • GMLIII
              • May 2013
              • 2802
              Coastal was about a $5000 upcharged. I use in fresh water now but bought coastal model because we may be moving to the gulf within 24 months .
              Coastal comes with built in auto flush, all gas seat hinges are stainless bodies vs plastic, tower and windshield frames is powder coated, has extra water filtration system required by many coastal area and state controlled reservoirs., fresh water system vs raw water cooling system ( antifreeze required ). These are the major differences
              • mstober
                • Jun 2018
                • 2
                • North Carolina
                Thanks for the advice all... looks like I'll be looking at new boats this weekend!!
                • tsatrooper
                  • Apr 2017
                  • 17
                  • Ohio
                  • G25CE 38fountain 02san 96sport
                  I bought g25 coastal edition a little over a year ago and it had 50 hrs of salt water use and you could tell. I had to have several items stripped, baked and recoated due to corrosion. Salt is tough on them. I do however have a 1 year old, boatmate galvanized trailer that i would swap if you interested. I would say if you put a flush kit on it and wash it down and flush it out after every use you would be ok.
                  • fearocks
                    • Jul 2019
                    • 62
                    • Colorado
                    @GMLIII looking to purchase either a G23, or G25. I'm planning to keep it in Austin, however, just in case I bring it down to Miami, looking at the Coastal Edition. I'm thinking the G23 with the 450 (one less thing to break w/o a supercharger and considering the ballasts are the same and should get deeper drag = bigger wakes with the lesser displacement of the G23). Does anyone have any suggestions on size and engine as it correlates to saltwater / rougher seas?
                    • GMLIII
                      • May 2013
                      • 2802
                      I don’t think the 550 would make any difference with salt water vs rough seas than the 450 IMHO
                      • fearocks
                        • Jul 2019
                        • 62
                        • Colorado
                        Great, I didn't think it would, but wanted to get a second opinion! Any thoughts between the G23 / G25? It looks like you went with the G23.... I'm also thinking the 23, for a better wake, but not sure if that'd be the case. What made you go with the 23, if you don't mind me asking?
                        • GMLIII
                          • May 2013
                          • 2802
                          Better wake out of the box vs 25 even though I tweaked mine with 750 lbs of steel shot bags . Even if yuh don’t go in salt water I think the $5000 upgrade for a Coastal model is worth it fir the options and heavy duty featured offered
                          • blueroom
                            • Mar 2017
                            • 623
                            • Northwest
                            • G23
                            Does the Coastal still get only 3 years of warranty, or did that change recently? I seem to recall there might have been a change.
                            • fearocks
                              • Jul 2019
                              • 62
                              • Colorado
                              Good question, I'll ask the dealer and post if anyone hasn't
