Originally posted by fearocks
View Post
I don’t own a trailer . Just use my boat lift for storage
Originally posted by GMLIII View PostKeep a close eye for fit and finish on the Malibu not on par with Nautique or Mastercraft
We have a coastal edition GS22 , my partner on the boat wanted to be able to use it in the bay while I prefer freshwater lakes or rivers. It probably has about 75% of the use in freshwater but I do have to say that the salt water is obviously a lot harder on everything. We use the flushing system to flush the cooling system on the engine but there’s no easy way to flush the ballast pumps and tanks every time we use the boat in salt water I noticed just how rusty and crusty things get and how rapidly that happens. When I took apart the ballast pumps to put in new impellers they look horrible inside and already had significant rust on the impeller shafts. You have to be much more diligent about cleaning and maintaining a boat used in salt water that’s for sure.
Originally posted by estebanw View PostWe have a coastal edition GS22 , my partner on the boat wanted to be able to use it in the bay while I prefer freshwater lakes or rivers. It probably has about 75% of the use in freshwater but I do have to say that the salt water is obviously a lot harder on everything. We use the flushing system to flush the cooling system on the engine but there’s no easy way to flush the ballast pumps and tanks every time we use the boat in salt water I noticed just how rusty and crusty things get and how rapidly that happens. When I took apart the ballast pumps to put in new impellers they look horrible inside and already had significant rust on the impeller shafts. You have to be much more diligent about cleaning and maintaining a boat used in salt water that’s for sure.Last edited by fearocks; 07-29-2019, 03:36 PM.
Nope wishful thinking , rumor mill and expectation. No 2019 nor 2020 model surf select optioned boats will function with the Garmin Fenix watch . If you have either of these model years , the surf select system will only work with the Pebble watch . Sell you Garmin Fenix and buy a cheap $50.00 Pebble watch on EBay . Just Saying
- May 2013
- 2792
- Smith Mountain Lake, VA (Craddock Creek area)
- 2017 G23 Coastal Edition H6 | 2001 Sport Nautique | 1981 Ski Nautique
Originally posted by fearocks View Post
They did end up releasing the app for the Garmin Fenix, however when I tried to download it, it only works on the 5 Plus series, which just came out. It kinda sucks that they expect people with existing watches to go out and spend another $750/ just to download an app, when the only thing Garmin added to the watch was local music storage. I'm guessing that must be a Garmin thing because I don't see a technical reason why it can't work on the existing watches. Fingers crossed that it will still work on Pebble, otherwise I'll have to sell my Garmin on Ebay and buy another.
- Jul 2019
- 103
- Prior Lake, MN
- '15 Super Air Nautique 210 ''18 Bennington 25 spdxp '16 SeaDoo gtr 215 (2) '16 Yamaha SuperJet
Just purchased a 2015 SAN 210 Coastal that had a couple of years and over 1000 hours of salt use and moved it inland here to MN. It was priced $20k less than comparable non-salt used boats of that model in the market. Other than some cosmetic issues making it look a bit prematurely aged, everything on it is in pretty good shape considering. I can fix or repaint a lot of stuff for $20k or just enjoy having that extra money in my pocket.
- May 2013
- 2792
Originally posted by LakesideRec View PostJust purchased a 2015 SAN 210 Coastal that had a couple of years and over 1000 hours of salt use and moved it inland here to MN. It was priced $20k less than comparable non-salt used boats of that model in the market. Other than some cosmetic issues making it look a bit prematurely aged, everything on it is in pretty good shape considering. I can fix or repaint a lot of stuff for $20k or just enjoy having that extra money in my pocket.
- May 2013
- 2792
The Port side does fill a bit slow compared to the other side. So maybe that pump has some issues. Will check it out.
- Jul 2019
- 103
- Prior Lake, MN
Hopefully just the impeller needs to be replaced but you may discovered the whole pump is completely corrode from salt water once your open the pump cover
