I've got an 85 ski natique w/351 pcm. Running 30 weight. Oil psi @ idle is 20 (after warming up). The gauge is fine, but the "idiot light" comes on. At about 1200 rpm's it goes out. Max psi reads about 45-50. Anyone else ever had this, the light is driving me crazy..Thanks
seem to have solved the problem. replaced oil and filter w/10w40. Had already replaced sending unit, but used teflon tape to seal the threads. Cleaned threads and used anti-sieze, which is conductive. Oil pressure at idle is now @ 20 and under load is a steady 50psi. I really think the teflon tape was effecting the ground. Seems to be working fine now..Thanks
