Transmission will not go into reverse.
  • Joe Rack
    • Jun 2018
    • 2
    • Illinois
    • 2016 SAN 210
    I have a 2016 SAN with about 70 hours on it. Boat has been awesome. Today we were surfing for about 20 minutes. Went to pick up fallen surfer and no reverse. Forward gear works fine. Quick check of trans fluid and it looked pink with no smell. I did not confirm fluid level.
    First day of vacation! Any thoughts, help or advise?
    Thanks!
    Joe
  • ironj32
    • May 2011
    • 601
    • 2018 SAN G23 XR550
    My quick guess would be that you lost reverse, and might need a new transmission. Not sure if they can just replace the reverse gear or not?
    2018 SAN G23 XR550
    2015 SAN G23 XR550
    2014 SAN G23 XR550
    2013 SAN G23 XS550
    2013 SAN G23 ZR450
    2011 SAN 230
    2010 SAN 230
    2000 XStar
    www.mnspringride.com
    • Joe Rack
      • Jun 2018
      • 2
      • Illinois
      • 2016 SAN 210
      Thank you for the reply. NOT what I want to hear! I was hoping a relay issue or something simple.
      • Tom_H
        • Jan 2014
        • 244
        • Minnesota
        Could try unplugging and reconnecting your throttle by wire plugs. It's possible that the reverse shift signal isn't making it.
        Sent from my G3423 using Tapatalk
        • ironj32
          • May 2011
          • 601
          Hopefully Tom_H is right. The 230 that we lost reverse in was a 2011...now that they no longer have a cable throttle, losing a signal makes sense.
          2018 SAN G23 XR550
          2015 SAN G23 XR550
          2014 SAN G23 XR550
          2013 SAN G23 XS550
          2013 SAN G23 ZR450
          2011 SAN 230
          2010 SAN 230
          2000 XStar
