Change The Prop on a 2009 230 TE
  • abpoulin
    • Sep 2015
    • 13
    • Maryland
    • 2009 Air Nautique 230
    I have read a couple of posts about changing props, and wanted to get some fresh opinions on methodology.
    It sounds like you loosen the nut if using a clamp, or remove completely if using the harmonic removal tool (since it will catch the prop).
    The acme prop is ordered comes with the harmonic removal tool so I'll give is a shot.
    Also, I have watched a couple of videos about removing the prop, and they all have cotter pins.
    The end of the shaft tapers and there is not a spot to put a cotter pin.
    Anybody have thoughts and/or input on removal/installation of the prop?
    Thanks!
