Adjusting idle on a 5.7 PCM engine
  • Aggerskk
    • Jul 2018
    • 5
    • Loveland, Colorado
    • 2016 Naurique 200 OB
    Is there an easy way to adjust the idle on my 5.7 L PCM engine without taking it into the dealer mechanic. I live some distance away from the dealer.
  • scottb7
    • Aug 2011
    • 2198
    • Carson City, Nevada
    Why do you need to?
    • Aggerskk
      • Jul 2018
      • 5
      Boat is idli g too fast prior to pulling a skier out of the water, and also a bit fast in the "no wake" zones on our public lakes.
      • scottb7
        • Aug 2011
        • 2198
        What is idle speed? I don't think you can adjust without diacom system...it should be 650, i think.
        • Aggerskk
          • Jul 2018
          • 5
          Thanks for the response. Not currently on the water, but will check actual speed and rpm tomorrow. I was pretty sure that the dealer would have to re-set it.
          • Aggerskk
            • Jul 2018
            • 5
            Also, engine is the 5.3 H5. Mis-stated it on the original post.
