G23 headlight went out...troubleshooting help.
  • Tallredrider
    • Oct 2014
    • 1026
    • St. George, Utah
    Although it may be a warranty item, my dealer is so slow, I will consider fixing it myself.
    The right docking light stopped working on my 2016 G23. It is interesting that this is the first time I have used them since it had to be removed to fix a gelcoat mishap.
    The green running light works fine, but when the docking light is turned on, the green light goes out and the docking light on that side does not come on. Are these lights sharing a common ground? Maybe the gelcoat repair guy put the wires back together incorrectly? I have yet to pull it, but wondered if anyone knows what the wiring should look like behind the light before I tear into it.
