G23 temp
  • chrisschweda
    • Sep 2010
    • 140
    • New Orleans
    • 2015 G23
    G23 temp
    I have a 2015 g23 what temp should i be running I am anywhere between 160-175 sometimes up to 180 or so I have fresh impeller in and it is a coastal edition if that matters. What temp are most ppl running
  • tcaviness
    • Nov 2015
    • 48
    • Lewiston, ID
    • 2015 G23
    Same
    • scottb7
      • Aug 2011
      • 2198
      • Carson City, Nevada
      2014 G21: This time of year with water at 80 degrees...I am usually between 163-176, depending on idle vs pulling rider. I noticed if after cleaning the strainer it brought it down to 172...
      My 210 ran a bit cooler. Not sure if this is normal for a G or if my thermostat is getting a bit tired...
      • Bevostein
        • Jun 2008
        • 523
        • Frisco, TX
        My G25 runs 172ish pretty consistently
        • GMLIII
          • May 2013
          • 2797
          My 2017 G23 Coastal Edition runs around 171 but they say the partial closed cooling systems (requires anti-freeze) run hotter than raw water cooling systems
          • blueroom
            • Mar 2017
            • 623
            • Northwest
            • G23
            XR7 in ‘16 G23 runs right at 180 all the time. Fresh impeller.
            • RDT-G23
              • Jun 2017
              • 589
              • TEXAS
              • 2020 G23 PARAGON I 2017 G23(sold)
              What he said... I have a 2017 G23, (fresh water cooled) and it runs 165* religiously on a Texas Hill Country Lake with 100*+ air temps and ~80* water temps.
              • GMLIII
                • May 2013
                • 2797
                With that said his engine is running cooler than mine even though my days in Virginia are not as hot and the water temp is lower . I often thought mine was running hot but it is what it is.
                • chrisschweda
                  • Sep 2010
                  • 140
                  • New Orleans
                  • 2015 G23
                  Our water temp right now is over 90 degrees
                  • GMLIII
                    • May 2013
                    • 2797
                    We are in the low 80s with water temp so if your water temp is over 90 and your engine water temp runs between 160-175 you are doing well for a Coastal Edition. My Coastal Edition will run 171 all day long, new impeller as well.
