The "timmy T either vibrated open or was accidentally left open and engine overheated severely. Raw water pump disintegrated in the process, of course. So, I replaced the impeller and cleaned all debris I could find from the old impeller. The water pump is now pumping well out its exit and into the cover fir the thermostat but the engine is still overheating after about ten minutes of running. I don't think cooling water is getting into the block...HELP?
What is the impeller on the automotive type water pump, bolted to the front of the engine, made of? If it's plastic maybe it got fried too, or maybe some fragments of the old rubber impeller became lodged in the water entry passages in the front of the block.
if your impeller got shredded.......most likely there is a piece in your loop still causing bad flow.........I had 2 pieces the size of eraser heads stuck in the v drive housing that kept mine from running and not overheating......and of course.....it was the last place I looked. But I did find pieces in all the other areas when I took off the hoses. Amazing how little pieces get stuck in there and cause the overheating. Not sure if this helps. D
A d m i n i s t r a t o r
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
Check your transmission cooler for pieces of the old impeller. This is a typical spot for them to get stuck.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
