Deepish Gouge in my G23 red metal flake
  • sarasetp
    • Oct 2016
    • 112
    • Bellevue
    • 2016 G23
    I am killing myself because I was backing up next to the dock and when reaching for the dock, I nudged the reverse down and sped up the boat along the dock, gouging. 1.5 foot section under the S in the Super lettering on the boat. The gouge runs along the red metal flake and a little deep and about half a pinky in width. The red still shows under the gouge. So how expensive was that mistake? Know any good repair folks in the Seattle area? I want to kill myself now.
    2016 G23
  • Evening Shade
    • Apr 2015
    • 1295
    2016 G23
    How deep is the gouge? Is down to the fibers or just gel coat? Post a pic.
    I'm no expert on this, but the key is finding a really good fiberglass repair guy because metal flake is difficult to repair. Also dark colors and red are really hard to match even with factory gel coat. You probably won't want to turn it in on your insurance, but call your insurance company and talk to the local insurance adjuster in your area and ask him who does the best fiberglass work. He should know who is good and who to avoid. You can ask your dealer who is good, but they may tell you that they are good just to get the business. The insurance adjuster will give you an unbiased opinion on work that he has seen.
    I'm speaking from experience here because I learned these lessons the hard way.
    The repair will most likely be less than $1000, maybe less than $500 depending on how deep it is.
    • Infinity
      • Sep 2017
      • 730
      • Lake Norman - Denver, NC
      • 2014 SV244 w/ ZR409
      If its not too deep, it may be something you can get out yourself. I we-sanded, compounded and polished my boat this Spring and have a lot of metal flake on the sides. Granted nothing was deep...I was able to lightly wet-sand with 2000 grit, then compound and then polish, came out perfect. Its when you go thru clear coat that you start having issues, if that is the case you need the original flake used and skills. Cost should not be too crazy, just don't expect to get it done till after season is over
      • sarasetp
        • Oct 2016
        • 112
        • Bellevue
        • 2016 G23
        Here are some pics...Not sure if you can tell how deep the gouge is
ID:	562931 Click image for larger version
ID:	562932 Click image for larger version
ID:	562933 Click image for larger version
ID:	562934 Click image for larger version
        • xlair
          • 694
          • Wisconsin
          It’s definitely repairable but best left to a pro
          2001 Pro Air Nautique
          • Infinity
            • Sep 2017
            • 730
            Yea, looks kindof deep. Guessing that will need some filler and pro work since usually with new gel-coat filler they actually make the gouge a bit bigger so it sticks right and then redo it. With bright red flake like that....it will have to be done perfectly.
            Google gelcoat flake repair so you know the process. I think he is right.....500-1000 depending on who you use.
            • lucky7t
              • Mar 2011
              • 1306
              • Oklahoma
              • 2015 SANTE
              First things first . You and your family are safe .
              Contact a good detail company that specializes in paint correction . Try to see if you can color sand it and buff . I canÂ’t tell if that black in the scratch is the boat or from the thing that scratched it.
              Many shops color sand so call around . You really have nothing to lose .
              If repaired I will tell you metal flake isn’t easy or cheap . I paint for my living . Touching that up won’t be fun . It can be done though
              I had a huge chunk taken out to the glass right on my nose of our 07 from a moron loading my boat when I was out if town. I gel repaired it . It really wasn’t bad but you have to do it right . You couldn’t see where the repair was
              Current Correct Craft Boat
              Correct Craft Boats Owned
              • blueroom
                • Mar 2017
                • 623
                • Northwest
                • G23
                That sucks. We have red metal flake as well. I am sure you can find someone up there, the nice thing about living in a larger area. I know there is a guy that works with the Central Oregon Nautique dealer that does some pretty incredible work - but that would be a haul for you. My real point being that it can be fixed well if you find the right person.
                • greggmck
                  • Oct 2014
                  • 795
                  • Bellevue WA
                  • 2023 Paragon G23
                  Call Pacific Nautiques and ask who they use. Standard gel coat is easy to repair. Metalflake is best left to pros who work on these colors. Thats why you want a recommendation from the dealer.
                  • surfnjosh
                    • Jul 2016
                    • 104
                    • Canada
                    • 2021 G23 2020 G23 2017 G23 2013 G23 2012 230 Team
                    The flake is actually pretty easy to match color wise, the issue most guys have is the Clear layer clouding up..... So there tends to be a haze where the repair is... It would be worth a long drive if you KNOW of a very good gel guy, I know in my neck of the woods these are very few and far between....
                    Sorry but that's not coming out via wetsand/polish.
                    • RDT-G23
                      • Jun 2017
                      • 589
                      • TEXAS
                      I agree with what has been said above-at least you are all safe. That said, this is a job for a pro for sure.
                      • blueroom
                        • Mar 2017
                        • 623
                        • Northwest
                        • G23
                        Please post some after photos. I am interested to see how it looks.
