2010 200 raw water pulley cracked.
  • fpjl
    • Jun 2014
    • 46
    • NC
    • 196 2005 200 2010 G21 2016
    My 2010 200 has been making a clicking sound for about a week around the serpentine belt. I thought I needed to change the belt. Today however the raw water pulley cracked and the belt fell off. I plan to replace the pulley, impeller, and belt but I wonder if the raw water pump itself is the problem. Thoughts?
    [ATTACH]n562978[/ATTACH] Click image for larger version
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    WOW! In nearly 20 years of being in, on and around Nautiques I've never seen a raw water pulley do that. I doubt the pump itself is bad unless there's something wrong with the spindle.
    -Charles
    • Tom_H
      • Jan 2014
      • 244
      • Minnesota
      Like Charles said, pump is probably ok. When you pull the impeller out, just make sure the pump spins freely.
      • ally505
        • Feb 2012
        • 180
        • Somewhere cold and wet
        • 2008 super air nautique 210, zr6.
        The crank pulleys do go, I changed mine (as it was corroded) when I bought my boat to avoid belt dust, the dealer keeps them in stock as they crack on a regular basis.
        • fpjl
          • Jun 2014
          • 46
          • NC
          Many thanks for your replies. Talked to skidim.com today and they confirmed that these do crack. Overnighting the parts which is awesome. Will report back.
