octane rating pcm engines
  • FEVB
    • Jun 2017
    • 68
    • Brazil
    • G23 2019 450
    What the below PCM statement means? Is it safe to run any PCM engine including the 550 with regular fuel ? Tks
    Pleasurecraft fuel injected engines are calibrated to operate on 87 octane fuel and maximum performance is obtained when using this fuel. The ignition timing set by the factory requires the use of a high-quality lead free regular gasoline with an octane specification of (R+M/2).
    Last edited by FEVB; 07-22-2018, 04:25 PM. Reason: Read the engine manuals. Case closed
  • FEVB
    • Jun 2017
    • 68
    • Brazil
    • G23 2019 450
    Case closed
