SV211 idling high
  • Ronix3131
    • Jun 2018
    • 8
    • SoCal
    SV211 idling high
    Hey guys - I got an 06 with PCM Excalibur 330. Just today it started to idle up around 900rpms when usually itÂ’s at 600. It seems to only do it when it is up to normal operating temp. When it is cold or been off for a while it idles normally. Any thoughts on where to start looking?
    Thanks in advance!
  • Ewallace
    • Mar 2012
    • 83
    • Park Hill, OK
    • Air Nautique 211-SV TE
    You might check the engine hood. Mine started sagging over the years and put slight pressure on the throttle linkage. I put two flat washer on the bolts coming through the spark arrestor to raise it 3/16”. Problem solved.
