06 oil leak
  • G-man
    • Jun 2004
    • 428
    • Allen, Texas
    06 oil leak
    My oil filter when I first got the boat leaked at the top of the filter. I hand tightened it till I did the first oil change. Now it is leaking again at the top. I'm using a Motorcraft FL1-A filter. Anybody else having this problem? What filter are you using?
    Current
    2003 SkiNautique 206 LE Yellow - Black - Silver Cloud
    Previous Fleet
    2006 Ski Nautique 196 SE Titanium - Black- Silver Cloud
    2004 Ski Nautique 206 LE Red - Black - Silver Cloud
    1993 Mastercraft Stars & Stripes 190 Red
  • newair211
    • May 2006
    • 8
    RE: 06 oil leak
    Yes! My new 06 211 had an oil leak from the top of the filter while i was on the lake. My boat still smells like oil when it warms up. I flushed and cleaned it with a bio degreaser but it still smells. Any hints how to get rid of the oil on the engine etc. or will it eventually go away.
    • skiinxs
      • 374
      • St. Louis
      • 2019 Ski Nautique 6.2 arriving soon
      RE: 06 oil leak
      When I did my first oil change on my '06 I noticed that the sealing surface on the remote oil filter bracket had thick paint on one side. It looked like they didn't mask it properly when they painted the it causing a thick line of paint to be on the surface that the filter gasket is supposed to seal against. I am surprised that mine didn't leak, but you may want to pull the filter and see if you have the same situation.
      Dave
      16 other Ski Nautiques
      3 MasterCrafts
      18 Ski Supreme's
      1 SlickCraft Squirt Boat
      • Jesse1
        • Sep 2004
        • 78
        • East Texas
        RE: 06 oil leak
        The FL1A is for a Ford engine. The Excaliber is a GM engine. You need to check and see if the FL1A is the right filter for your engine.
        • MacedayDave
          • Oct 2004
          • 70
          • Norris Lake - Andersonville, TN
          • 2005 SN196LE
          The Excalibur 330 is a GM (Chevy) engine, but the remote oil filter adapter that PCM uses does indeed take a Ford-style filter. The Motorcraft FL-1A is correct, and an AC-Delco PF-2 also fits, which is the one I use.
          • G-man
            • Jun 2004
            • 428
            • Allen, Texas
            Update: Still have the oil leak after tightening a 1/4 turn more with strap wrench. We looked at my friends promo boat and his was doing the same. I guess I'll pull the filter off and look at the sealing surface for paint or anything else that shouldn't be there. My promo friend thought I was nuts till he looked at his.
            Current
            Previous Fleet
            • skiinxs
              • 374
              • St. Louis
              You probably already know this trick, but it you pull a large heavy duty zip lock bag around the filter before you unscrew it, you will avoid any oil dripping on the carpet.
              Dave
              3 MasterCrafts
              18 Ski Supreme's
              • krs0394
                • Jan 2006
                • 170
                • Sturgis, MI
                Dave
                I had never thought of that before / Thanks for the tip / Learn something new everyday
                1973 CC Skier
                1989 SN 2001
                2002 SN 196
                2005 216 Limited
                • skiinxs
                  • 374
                  • St. Louis
                  Happy to help out. Let me know if you find paint on the sealing surface of your oil filter bracket. If mine isn't the only one I'll let PCM know.
                  Dave
                  3 MasterCrafts
                  18 Ski Supreme's
                  • Flyerace
                    • 39
                    Try checking the two flange fittings that come into the remote oil filter housing. Mine was/is leaking from there and then drips onto the top of the filter. After retightening them, the leak slowed down, but is still there. 330 Excaliber.
                    • Quinner
                      • 2246
                      • Correct Crafts
                      Probably not the problem but be sure that the old oil filter O-ring gasket was not left behind before the new filter was installed, that will definitely create a leak. As Dave said the Ford filter is correct for the remote adapter on an Excal 330.
                      • G-man
                        • Jun 2004
                        • 428
                        • Allen, Texas
                        The old gasket was still attached to the old filter. I was just at the dealer and this is not new problem for the remote filter mount. He is faxing me some information later.
                        Current
                        Previous Fleet
                        • G-man
                          • Jun 2004
                          • 428
                          • Allen, Texas
                          flyerace turns out your on to something, I got the service update and it says to check the o-rings leading in and out of the remote filter.
                          Current
                          Previous Fleet
                          • Flyerace
                            • 39
                            G-Man,
                            If this is a bulletin, can you post the service bulletin number? I will be asking my dealer to check the o-rings where the oil lines run in and out of the remote housing. Let me know how it turns out. Thanks.
                            • jefe
                              • 257
                              • Orlando, FL
                              Dave-
                              Check with Dan at Extreme as this sounds very familiar to the problem I had on my 04 210. Not to sure about the extra paint though.
                              PCM had issues with the oil filter metal attachment ring on the Excalibur not correctly sealing to the filter. It was either cracked or compromised in some way. They had to replace that part and it was a recall/warranty issue.
                              Seems like they would have learned from their mistakes in 04. (PCM)
