engine stalls when horn button is pressed
  • neilryp
    • Sep 2017
    • 2
    • Hague NY
    • 2009 Super Air Nautique
    I'm wondering if anyone has run it a problem when the press the horn button and the engine cuts out. My boat is a 2009 SANTE 230 with 409. The boat ran fine for the day if I didn't use the horn and when I returned I tried it again and the horn worked and all was fine.
  • functionoverfashion
    • Jun 2017
    • 509
    • New Hampshire
    • 2003 SANTE
    I've seen this on a much older boat where the wiring was corroded, old and sub-par going to the dash; the electrical draw from an otherwise normal accessory (the horn) would cause the engine to sputter, and other electrical weirdness on the dash. Maybe you have a bad connection, loose wire to your horn, something like that? It's too new for it to be corrosion, I would think.
    • neilryp
      • Sep 2017
      • 2
      • Hague NY
      Thank You
      • BT
        • Dec 2008
        • 77
        • Alabama
        • 2012 Super Air 230 1997 Super Sport sold
        I would suspect a bad ground. Loose or corroded
