It looks like there is a new replacement prop for the favored 3081 on the XR7 550 motors. Acme now has the 3345, which is identical to the 3081 (18 x 17.5 x .105) but has a shorter hub to match the 3" hub length on the stock props. I have talked to Acme and Delta Props, and this new prop was created in response to feedback and concerns with the 3081 3.375" hub getting the prop too close to the strut. I think this is also why the 3081 could not be used on the G21 and G25. BTW - Acme currently lists the 3345 as being an 18x17 on their site, but I am told this is incorrect.
Both Acme and Delta recommended the prop as an upgrade to the stock prop for the XR7 550 motor.
