Extra bags gs20
  • Kinloch
    • Jan 2016
    • 46
    • New zealand
    • 2018 gs20
    Extra bags gs20
    has anyone plumbed in some extra bags to the gs20 that can provide a basic how to guide.
  • BigAirBearWake
    • Apr 2018
    • 17
    • Lake Wylie SC
    • 2018 GS24 H6
    Wakemakers sells their piggyback system that allows you to plumb extra bags in the rear. For filling: Basically you T off of the STBD and Port Ballast pumps. Connect factory tank to one side of T and the other goes to the sac in the rear locker. For Venting/Overfill: Another T off the factory vent line and both vents will now exit through the factory vent. You will need a check valve. After that you will need to go into dealer settings and change quallaga (not sure if spelled correctly) filter to on.
    Once you add these extra bags you will need couple hundred lbs of weight upfront. IMO lead under front seats.
    • Kinloch
      • Jan 2016
      • 46
      • New zealand
      • 2018 gs20
      Thanks -that sounds pretty straight forward.
      domyou T directly at the pump or go down the fill line a bit?
      • BigAirBearWake
        • Apr 2018
        • 17
        • Lake Wylie SC
        • 2018 GS24 H6
        Wakemarkers is right off the pump. It has to be trimmed to fit. The pre fuel filter is pretty close1
