Pebble 2 wont connct to 18 G23 please help
  • Bottlefedsi
    • Jul 2015
    • 245
    • Clermont, Florida
    • 2023 G23 2022 G23 2021 G23 2019 G23 2018 G23
    Hello everyone, sorry if this has been discussed to death but I am stuck and hope you can help. I have read the other thread about converting to Rebble, which I have done, and installing the latest software and app for Pebble, however, I cannot get the boat to see the watch no matter how I try. Here is what I have, Pebble 2, acc on Rebble, updated software on Pebble 2, NSS app installed on watch, boat one see it at all. The only reason I want to use the watch is for surf select because I keep going through nautique buttons due to water intrusion. Thanks in advance.
  • kdonzi123
    • Nov 2012
    • 88
    • Lake Hopatcong
    • 2018 230
    You have to go through a process to get the Pebble 2 to work. My pebble 2 wouldn't work and had to use a Classic or a steel. How ever if you want to give it a shot , reset watch back to its original first time and select the Pebble older app. It's called pebble old version. The soft were has to be 2.8.1 or 2.9.1 . The pebble 2 has 4.3.1. So you might get lucky with that. But there is another thread that some one explains what he did. Good Luck.
    • charlesml3
      • Jan 2008
      • 2454
      • Lake Gaston, NC
      • 2022 G23
      I'm not sure which one the Pebble 2 is. According to the chart, the ONLY ones that work are:
      - Classic
      - Steel
      - Time
      - Time Steel
      The Classic and Steel must run Firmware 2.9.x
      The Time or Time Steel must run 3.x
