OK team I have been out on my buddies Supra this year 10+ times and decided to get my 2005 SAN out. I winterized it, put the plugs back in but when I push the start button after entering the code all I hear is the relay click. The batteries are Kirklands and are only two years old. I have two batteries and a perko switch, I generally put the switch in the all position and start the boat. I have never had any issues with the boat not at least cranking over but does anyone have any other advice? The things I have tried are:
-making sure it is in neutral - wiggling it back/forth
-the little plastic key that holds the button in, in case you get thrown out of boat - that does reset the electronics when removed so I believe that is working
-stereo and all other buttons on the touchpad work perfectly
-when power is on I hear the fuel pump kick in and also the perfect pass does its reset
-I have also added another battery just in case but the gauge itself shows just a smidge under 12v
When I push the start button - a small click in the relay - I replaced the fuel pump relay --- there are 3 of them in a bundle -- going to be looking to see if one of them is the starter relay (unless you know)?
Any other suggestions?
