G23 propshaft strut ?
  • chrisschweda
    • Sep 2010
    • 140
    • New Orleans
    • 2015 G23
    I have a 2015 g23 I was wondering how much of a gap do you have from the prop to the strut mine was rubbing under load I start looking and the bolts were totally out on 1 back motor mount and the other side was loose. I tightened it all up and had to adjust 1 mount and align it by eye and feel. It seems all good I just have a 3/8 gap in between prop and strut... What is your Gap
  • charlesml3
    • Jan 2008
    • 2460
    • Lake Gaston, NC
    • 2022 G23
    The gap between the strut and the prop isn't really all that important right now. The biggest concern here is the alignment. You need to have this fixed. Once the motor to driveshaft alignment is good, the gap between the strut and prop will take care of itself.
    -Charles
    • greggmck
      • Oct 2014
      • 795
      • Bellevue WA
      • 2023 Paragon G23
      The gap between the strut and the prop is also dependent upon the hub length of the prop. They come in various hub lengths that vary by 1/2 inch.
