Just topped off my oil, let it run and shut it down. After pushing the stop button, the "Low Oil" light comes on, but after checking it, the engine is full. Any suggestions??
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
Which engine?
What does the dip stick tell you?
Are you measuring when the boat is level?
A little over 5 for an excalibur, approximately 6 for a 409. These are not exacts, it is fine to be slightly low, very bad to overfill.2018 200 Team H6
2009 196 Team ZR 409
2005 196 Limited ZR 375
2003 196 Limited Excalibur
1999 196 Masters Edition
1987 ProStar 190
My 06 210 would do the same thing sometimes, its probably nothing to worry about like stated above if it bothers you, You could try and change the oil pressure sender to see if it fixes it.
Its not expensive and worth a try.Last edited by ScooterMcgavin; 08-04-2018, 06:06 AM.2009 Super Air Nautique 210 TE
1989 Sport Nautique
