I don't ski, so have not worked out how much for skiing.
But i know the hull responds with a smaller wake when there is more weight forward. Do you have a center ballast? If so try filling it to different levels.
Or a few people in the bow.
I would say If you put anything more than 300 pounds up front you will be able to notice a difference. I always fill my stock center ballast even when riding around the lake.
Be careful putting too much weight up front as you run the risk of burying the bow and taking on (lots of) water if you mis-judge oncoming wakes as you are running at slower speeds (i.e. retrieving a fallen skier). Before you go out and buy a bunch of weight, why don't you get a couple of (heavy) buddies to sit up front and get a feel for the handling, etc.
The stock center tank on my boat is 330 lbs. And i keep 120 lbs of lead under the forward bow seat. I know that much weight isn't an issue, as i keep my center tank full whenever on the lake. But can't tell you much beyond that.
For reference whenever I have a beginner and/or just cruising the lake I fill my stock belly tank full (330#) plus 500# hidden bow sac. Handles just fine and once used to it you can cross rollers fine, on a windy day with chop tho you will get a lot of spray over the bow.
Thanks for all the advice, really appreciated. Guess its time to buy bow sacs and something to stuff in the locker gives me a great excuse to the wife to buy some goodies
