Perfect Pass Display Not Working
  • jwerner
    • Jun 2018
    • 10
    • Waupaca,WI
    • 2006 SV-211 2018 GS22
    Hi all,
    I currently own a 2006 Air SV-211, and have Perfect Pass installed. Almost every time we go out to ski in the morning, the display will not work, yet it will still beep when we press a button and will otherwise work perfectly besides the display. After we go skiing and come back to the dock, turn the boat off for an hour, then go back out, the display will turn be on and work perfectly for the rest of the day. I have checked the voltage to the dash and am consistently getting 14V both when the display works and when it doesn't.
    Is there anything else that might be wrong as far as voltage or grounding goes, or should I just get a new display?
  • j2nh
    • Dec 2003
    • 628
    • Spread Eagle Wisconsin
    Let me know if you figure this out, we had one do the same on a club boat. We played with it, checked everything and finally just got a new one. Electrons can be fickle things.
    2018 200 Team H6
    2009 196 Team ZR 409
    2005 196 Limited ZR 375
    2003 196 Limited Excalibur
    1999 196 Masters Edition
    1987 ProStar 190
    • Andy3535
      • Nov 2009
      • 31
      • Sonsbeck Germany
      I had the same thing happen to our display on our 2006 SV 211,it was dampness getting into the display.....changed the display and never had a problem again...
      • ScooterMcgavin
        • 1478
        • 2014 SAN 210 TE
        I had this same problem on my 06 210. It is the display going bad and replacing it is the fix. Call perfect pass they can help you.
        1989 Sport Nautique
