Could use any guidance tonight from the group. Have a 2014 G25 with 550 hp motor. Went out surfing tonight and boat hesitated while surfing and then engine cut off. Tried again and same thing. Looked at system screen and had this. Other sign was took a while to get to speed.
P2112 code. Drained ballast and tried getting up to normal speed and didn’t have a problem. Had dinner and tried again and same thing when surfing but drained and got up to speed. Definitely smelled gas as well after it cut out. Code seems to be issue with throttle body.
Problem is it is Labor Day weekend and closest Nautique deal is brand new after Marine Max divorce son don’t think they have much experience and assume they won’t have the parts or time to repair. There is a Marine Max not too far away so may be a better shot?
Problem is I have about 4 hours tomorrow when dealers will be open.
Here are questions:
Anyone experienced the same?
Should I try and take apart and clean and see it it fixes problem?
Would replacing throttle body solve the problem?
Is it the same part as a car part? If so could it be purchased at auto parts place or try and buy from boat shop?
Any way to easily find the part number?
Thanks in advance for the help. Cruising is nice but not why I bought the boat....
Brandon
