2002 Ski Nautique GT40 Exhaust Smell
  • windsurfnut
    • Mar 2018
    • 69
    • Ontario
    • 2002 Ski Nautique
    Hi All,
    I have a new to me 2002 Ski Nautique with the GT40. Awesome boat.
    Boat runs really great, no starting issues, idles correctly, performs strong.
    However, I have a rather strong fuel smell from the exhaust, noticeable mainly when skiing behind it. I changed cap, rotor and plugs - everything looked good there. Clean burn on the plugs, and cap/rotor looked good. I've cleaned the ISC - the boat was a bit surgy when I got it, but all of the above has changed that.
    Thermostat was changed, operates at 170 degrees.
    I just have no tell tale signs of running rich, it just is fumy. Is this normal? I have stumbled on that comment before.
    Is there a temp sender separate from the gauge that could be reading cold and ECU is dumping extra fuel (although my plugs showed no sign of that)
  • beamons
    • Jun 2017
    • 376
    • Utah
    I wish I could be of more help on this. I am struggling with a few things on my GT40. I would suggest checking out the CCFan forums. They focus a lot more on these older type engines.
    • FMSKI
      • Aug 2010
      • 177
      • Sproat Lake
      • 07 SV211 Ltd 343 Sold (Ski 200, TSC1, 2001)
      Old thread but until I got new injectors, my engine was the same. The old injectors were pretty dirty, and leaked.
      • windsurfnut
        • Mar 2018
        • 69
        • Ontario
        • 2002 Ski Nautique
        Just checked fuel pressure. Primes to ~30psi then drops to zero FAST. Suppose that is a very leaky injector?
        • fsts2k
          • Nov 2004
          • 215
          I had a similar issue in a Jeep, same thing, leaky injectors
