I am having a slight hesitation problem with my 1994 SN GT-40. Its carureted and overall, it runs like a dream! However, while sitting at an idle, getting ready to hit the gas or pull up a wakeboarder, it gives a slight hesitation and then clears itself and goes perfectly fine. I am pretty good with carburetors and tuning, but I wanted to make sure there wasnt any problem that others have experienced first before I start playing with it. I plan to replace the spark plugs tonight to see if that could be causing it. I run only 93 octane in it as well. So, before I go turning screws on the carb, does anybody have any hints or tricks for this problem? It almost seems like the carb is dumping too much fuel when I move the throttle lever.......Any advice would be great. Thanks
