1994 351 Sport Nautique
  • Acarter864!
    • Sep 2018
    • 3
    • Lake Greenwood,SC
    • 1997 Sport Nautique
    Ok I need any bodies help who may know what I'm talking about or has heard of this. I found a post on here a couple of years ago and of course it was on aa old phone. I don't haver it now and can't find it. Our Nautique wants to start cutting out when ever we pull the kids on the tubes and the motor gets hot and RPM's are up. This boat is fuel injected so its not a carb thing. When ever it does this mysterious cutting out, if you cut the motor off and then restart its like it resets. But then if you are back up to 3000 rpm it will start cutting out again. It had something to do with "spacing" on something! I had seen a post like I said on here before that a gentleman was having the same exact thing happening to his Nautique. Anybody with any ideas, suggestions are greatly appreciated. Tx
  • Zride
    • Dec 2017
    • 44
    • California
    Check the lanyard kill switch.
    • glassywaters
      • Jan 2015
      • 225
      • florida
      • none
      Does your boat have the protec system on it? 94 MY didn't specifically have fuel injection. Only a hybrid system. Your issues sort of sound like a protec system going bad. When the protec system goes most replace it with a carb. There is a conversion kit.
      • Acarter864!
        • Sep 2018
        • 3
        • Lake Greenwood,SC
        Done that, no problems there.
        • Acarter864!
          • Sep 2018
          • 3
          • Lake Greenwood,SC
          They have been threw the whole fuel injection system and it seems to be working fine. This is the thing, it doesn't do it all the time. If your just crusing down the lake it runs perfect. Just when you start pulling someone sking or tubing and you hit that 3000 or over rmp it will start cutting out. I don't know its crazy.
          • Tom_H
            • Jan 2014
            • 244
            • Minnesota
            You may have a coil-pack going bad on the protec ignition, where it may start missing at higher loads/temps. Usually when they go, they'll look melted somewhat, so you can visually inspect them. Otherwise, possibly a fuel pump issue where it doesn't have enough oomph to supply at the higher loads. The TBI portion of that engine was generally pretty stout, and it's usually the ignition system that will eventually fail and necessitate swapping to a carb. Vince over at SkiDim is pretty well versed on that engine, and would probably have some good info if you call him.
            • Tom_H
              • Jan 2014
              • 244
              • Minnesota
              Thinking a little more on this, check your anti-siphon on the fuel tank as well.
              • gary s
                • Mar 2015
                • 334
                • Algonquin IL
                I thought I saw about a month ago on Correct Craft Fan that someone figured out how to replace the protec ignition system but still keep the TBI. I'll see if I can find it and link
                • gary s
                  • Mar 2015
                  • 334
                  • Algonquin IL
                  Ok got it,had to enlist another CCf'er to do the search. Turns out it was 10 months ago. Titled Keeping your Protec EFI with a DUI system
