Anyone using the T system...do you have a pic of the T installed? Does it have some type of threaded cap on it? Or even just a picture of the necessary hardware. Thanks
I have a Mercruiser flush kit on my 08 210 and have the quick connect mounted on the exhaust riser.
https://www.google.com/shopping/prod...QCgBzMQgTYItwQ
Sent from my iPhone using PLT Nautique2008 210 SANTE
On my 210 it is on the hose that runs out of the strainer and down by the trans cooler. Hopefully this makes sense to you. Is all you have to do is cut the hose, install the T and mount the bracket and fitting.
