Check Engine Light
  • Byerly 2011
    • Jul 2015
    • 4
    • Wake Forest
    • 2011 Byerly 210
    Check Engine Light
    I have a 2011 210 with a PCM EX343 motor. The check engine light is coming on when the boat accelerates
    above 24 mph. If I cut the boat off and restart keeping speed under 20mph the light will not come back on.
    Anyone had this issue before?
  • Evening Shade
    • Apr 2015
    • 1295
    When the check engine light comes on do the readings on any other gauges change, such as water temp, oil pressure?
    • Byerly 2011
      • Jul 2015
      • 4
      • Wake Forest
      • 2011 Byerly 210
      Sorry for the late response. The oil pressure and engine temp seem to be fine. All gauges are working properly.
