G23 Keel Guard
  • brit_hunsicker
    • Oct 2014
    • 482
    • Overbrook, KS
    • 2001 Super Air Nautique
    G23 Keel Guard
    Has anybody out there done any sort of a keel guard on a G23 on 16’ or newer after they got away from the flat front end? The original owners of this boat did not pull the boat far enough forward on the trailer so going down the road it must have bounced up and down and blown the gel coat out right above the hook. The dealership “fixed” it before we picked it up but then it supposedly blew out again before they made it back to the dealership. Apparently this is a common problem with Gs? Here are some pictures of the blowout and what the plan was to use after the gelcoat was fixed again. It would have worked great and looked pretty good as well, but even though that angle on the front of the boat looks the same from top to bottom it is far from it. There is roughly a 12 degree difference spread out over 18”. To make this plate fit right it would take some pretty intricate work.
  • GMLIII
    • May 2013
    • 2795
    I would just patch again with fill then get the Spectrum Color exact gelcoat color match. The other option is the rubber keel guard but I think they look awful. This would not be a bad fix with fill then applying the Spectrum Color gelcoat patch
    • brit_hunsicker
      • Oct 2014
      • 482
      • Overbrook, KS
      Yeah the rubber keel guards look horrible on a Bayliner. I’d hate to know what it would look like on a G lol. Hoping to come up with some idea though to protect against future blowouts. Now that the area has been compromised it is very vulnerable to future issues. And it’s in a high impact area.
      • GMLIII
        • May 2013
        • 2795
        I do like that plate, ashame it won’t fit . Maybe you could use same design but the product would be hard rubber vs metal ?
        • homer12
          • Feb 2016
          • 584
          • Indianapolis, IN
          • 2004 SV211 TE
          Could you modify the trailer instead of the boat? Ie use some bow bunk stops or something? Might cost more but be easier to set up than that plate.
