Winterization in NC
  • seveet
    • Oct 2014
    • 185
    • Muskegon, MI
    • 2015 SAN 230
    Winterization in NC
    Just moved to North Carolina. I am storing my boat in indoor heated storage. Do I need to bother winterizing or just routine maintenance? In Michigan I still winterized even with heated storage just in case. My local maintenance person did not recommend it.
    thanks
  • Evening Shade
    • Apr 2015
    • 1295
    Well that depends on how dependable the heat source is where you store the boat and whether you can easily check to ensure that the heat is working on cold nights.
    I personally wouldn't trust this scenario unless it was at my house where I could check it frequently. Too much at risk, IMO.
    • MLA
      • Dec 2009
      • 1312
      • Lake Wylie NC Area
      If the heat fails, and depending on the building construction and how long the heat out goes unnoticed, it can get cold enough in NC to freeze and crack a block. Besides, it takes 30 minutes or less to drain the typical boat drivetrain.
      • Nautiquehunter
        • Jun 2008
        • 2080
        I live in Georgia [Lake Lanier] for the last 7 years I have kept all my boats inside a 40x60 unheated building . I keep a bottle of water on a shelf near the door. It has never froze. That being said I still winterize all of them just like I did in IL. The only difference is no fogging and protection only down to 0. It sounds like you will be fine doing nothing but for 20.00 and 30 min of time do you want to chance it?
        • 75Tique
          • Apr 2008
          • 67
          • Seven Lakes NC
          Just to echo others. Yes it can get cold enough in NC to crack a block. Happened to my neighbor. Full blown winterization like we used to do up north, not necessary. Drain the block to be on the safe side, absolutely. Our layup is shorter so other aspects of winterization are not necessary and on that occasional lovely 50 - 60 degree winter day, I've been known to drop in my boat for a quick pull, followed by the 10 minute drain again procedure.
          • obd666
            • Feb 2010
            • 793
            • Bostian Heights, NC
            • 03 SANTE
            That is fascinating. In contrast, here in NC (outside of Charlotte) last year for instance the ol' water bottle froze many times in my unheated garage. We had a particularly cold winter last year, but just goes to show the difference a little latitude and elevation makes ...
            In short, yes I would at least drain the water out of the block. It's too easy and cheap not to, and takes miscalculation mostly out of the equation.
            2003 SANTE - "OG 210"
            • charlesml3
              • Jan 2008
              • 2454
              • Lake Gaston, NC
              • 2022 G23
              Yes and do not forget to drain the heater (if you have one). I can't stress this enough. The heater core will freeze and split long, long before the block does.
              -Charles
              • 75Tique
                • Apr 2008
                • 67
                • Seven Lakes NC
                Not sure if the new boats have a flimsy, easily cracked, copper transmission oil cooler like the old boats do, but I always make a point of draining that too.
